ACV: Cryofire
Gradeus
GamerTag: Caligo Iridis
ACV: Cryofire
Postby Gradeus » Wed May 16, 2012 10:47 pm
AC: Cryofire
Normal Mode/Scan Mode EN: 5028/11333
UHD-13 Galahad
UCR-10/A
KT-4S2/Svir
KT-2N3 Putuo
UFC-11 Glance
UGN-70/Ho Vital
BT21 Shinatsu
URD-36/ER
UMM-21 Dimapur
Seidenbaum SR13
Seidenbaum SR13
Oxeye HG25
Oxeye HG25
Strategy
Typical sniper, the frame isn't all that OP as much since the patch. This is more of a stunbot, use the Seidenbaums for long/normal range and the Oxeyes for closer range while moving back to a more comfortable position. Or if they're lighter, stunlock the poor thing with the Oxeye if you want/can.
Edit: Bumpdate since the patch. Changed things around a bit here. Good EN stats here so I put the Svir on instead of the Ilmenau.
Freelance Pilot and Designer
ACFA Builds:
Requiem: FW MG/R102/203
Thalia: FW 2x-Samp/Jads
Chevalier
GamerTag: ChaseNetwork
Re: ACV: Cryofire
Postby Chevalier » Thu May 17, 2012 2:57 am
What are the performance modifications on the weapon loadout?
Xbox Live GamerTag: "ChaseNetwork"
Time Zone: Zulu+9
Core Nexus (NA-360) - Unit [36]
Proud AC Architect
Wanabe Metalhed
GamerTag: Wanabe Metalhed
Re: ACV: Cryofire
Postby Wanabe Metalhed » Thu May 17, 2012 2:59 am
If in doubt, disconnect your internet.
Squall wrote:
Wanabe Metalhed wrote:
Chevalier wrote:Insert normal ChaseNetwork statements here.
Insert standard unusually bitter comeback here.
Insert angry, argumentative retort and unreasonable, un-enforcable demand to get back on topic, followed up by a lewd comment.
Gradeus
Re: ACV: Cryofire
Postby Gradeus » Thu May 17, 2012 1:02 pm
Can I get actual comments instead of flame-battles on every thread? :/
Lotus is Power, Akazien is Rapid Fire, KO-3K2 is Power, and the Elko is also Rapid Fire. Although since it's the lighter Laser Rifle I've been considering Power.
ACFA Builds:
Chevalier
Re: ACV: Cryofire
Postby Chevalier » Thu May 17, 2012 1:14 pm
You're experiencing EN issues aren't you? Specialized for Rapid-Fire reduces EN Consumption During Use on Thermal Energy weapons. Specialized for Power will increase that, and cause further issues with EN management.
Time Zone: Zulu+9
Proud AC Architect
Gradeus
Re: ACV: Cryofire
Postby Gradeus » Thu May 17, 2012 1:35 pm
It does? Huh... alright. The EN issues came from using drainy weapons, and the unusual Dhanbad for me. It was a good idea with the dual-shoulder availability, and was needed with Predire.
And on EN issues, I will always be looking for ways to increase output. Sometimes sacking a weapon is a good way, but I like to maximize combo potential while maintaining balance.
It's not as easy to keep a decent EN in ACV than in ACFA...
And I'm not too much of a spammer of my laser rifle shots *usually* so I've never really had EN issues with that on my Power and Rapid-Fire ULR-22/R's.
ACFA Builds:
Gradeus
Re: ACV: Cryofire
Postby Gradeus » Tue May 29, 2012 1:11 pm
Swapped Akazien for Seidenbaum, tossed Elko for ULR-22/R, swapped arms to KE (UAM-10/L), ditched shoulder as a result, and switched from Predire to Glance. This revision is a more energy-efficient model with more speed and a little less range. Lock speed remains effective with the Glance, and the weapon changes are personal preferences. Comments/criticism/concerns welcome.
It seems my EN skills are better than I thought, from FA. Improving is always good. Perhaps since I was running on 3.6k through the whole story.
ACFA Builds:
Gradeus
Re: ACV: Cryofire
Postby Gradeus » Fri Jun 15, 2012 7:11 pm
Huh. Bumpdate, this thing's now running dual Seids and dual Oxeyes. Latter is probably unnecessary but w/e. Suggestions welcome.
Changelog:
Arms to Svir from UAM-10/A.
Legs to Putuo from Wutain.
Shoulder to Dimapur from N/A.
Arm weapon to [Seidenbaum, Seidenbaum, Oxeye, Oxeye] from [Seidenbaum, ULR-22/R, KO-3K2, Lotus].
ACFA Builds:
Users browsing this forum: No registered users and 2 guests
